Here are some goodies for you. The folder contains 65 drum loops sampled from my crates. A few years ago I had created a DAW project where I loaded each break, did a bit of manual timing correction, and then sampled them at their root tempo to my Akai S900. The intention behind the timing correction was so that they would sound nice and tight with a drum machine. So I reopened the DAW file and sampled them each in to the S2400 at 26KHz mono. I also used a uniform sample naming convention of 11 characters, and the last three characters display the root tempo of the sample. So you can always see the root tempo when a sound is loaded. Also, because of the timing correction you can load a break, set to the root tempo, and the go to Loop/Slice-Multi mode and play the 8 pads on the 8th notes and it will play back the break without any slice artifacts. Very handy for doing easy change-ups with the drums.
Enjoy!
