Thanks for the reply…I bet that there could be endless possibilities, even to have one Heat on each output haha.
The Model 12 is used for both purposes: 1. a bit of EQ and Compression + Recording; 2. EQ and and the ability to split the 8 channels into my DAW - but here, I am not sure if the gear EQ setup is applied (I am not feeling the difference) maybe I need to play a bit more with my monitors and sub settings.
With the Heat I was thinking that I can manage manipulate my drums and my main sample more, to have that all glued togheter vibe. In this matter I don’t know exactly how to link the HEAT as for instance I have my drums on 1-2 and my sample/s on 3-4 - I am not a pro in the DAW either so I can solve that “issue” in there by mixing everything, but I am trying to avoid including the PC as much as I can - I have enough screen time everyday.
Another thing would be the volume. Even if I am bouncing the song directly from s24 or recording it in the Model12 it sounds too quiet.
