Error can not open folder
I get this error message quite often now when i try to assign sounds to pads.
So i cant load any sounds anymore.
When i start the machine again its fine but will happen again.
This happens only since the update.
Any ideas ?
If your current fw doesn’t say “UI: May 29” when you boot up, grab the latest firmware again. Should fix it.
