Running v1.28 on MBP 16in Nov 2024 (Apple M4 Pro silicon) macOS Tahoe v26.6.2 in standalone mode, controlling ASYX from Andromeda through iConnectivity MIOxc MIDI interface. Regardless of audio output selected, I get zero audio output (never worked with v1.24 or beta version either). ASYX remote control of panel over MIDI is partially functional ( fully functional with previous version v1.24 and beta). ASYX does not respond to note on/off or program change from Andromeda. MIDI channels are matched.
I have verified that Andromeda can trigger another external MIDI module.
I attempted to use a USB generic MIDI controller, restart ASYX, no audio output in standalone.
Tried MIDI Learn - doesn’t seem to respond. Confirmed MIDI channel and interface in ASYX. Tried other USB ports on MBP. MIDI Studio from applications\utilties\Audio MIDI Setup in Test Mode confirms MIDI activity from interface.
I can trigger library software instruments in Logic Pro from the Andromeda or USB controller. Haven’t tried using ASYX as a plugin yet, I’m a novice with LP and am on the learning curve.
Tried to isolate MIDI controller or MIDI interface, they all are functional with Logic Pro but not ASYX.
Sounds like something is wrong in your setup there.
Check what midi channel your andromeda is sending from, it could be that in logic pro you are using a track that listens on any midi channel, which would make it appear that there’s nothing wrong with your setup.
So, check your andromeda is actually sending on Midi Ch.1
B
I haven’t ruled out a setup problem on my part yet. Have to install a MIDI monitor app on my system. The input helps, I was running out of ideas.
Progress… standalone mode worked with MIDI ch 1 from my Andromeda, responds to note on/off, ribbon, wheels, aftertouch. But will not respond to other channels.
Upgraded to v1.29. Standalone now in midi omni mode, responds to ALL channels. How to I disable omni mode? Use Mix Mode? ASYX remote patch editing mostly not working. Any Program Change from Andromeda selects Edit Buffer on ASYX. Forgive my ASYX ignorance, need to read the user manual.
Checking A/B of patches between my Andromeda and ASYX. Most are pretty darn close. Some didn’t translate correct IE string patch has attack that is too fast. Plate reverb on ASYX is way louder than same patch on Andromeda. My compliments on the authenticity of the filters, I have “acid test” patches in my library and the ASYX nails most of them.
Haven’t done complete A/B, late night.
There’s a MIDI CC to toggle between PROGRAM and MIX modes, I’ll try that later. Very important for standalone, my goal is to use ASYX on stage in MIX mode. If ASYX doesn’t respond I’ll supply the MIDI CC details.
Quick peek at plate reverb ASYX vs Andromeda: while the values of effect settings match between the two, the effects engine on the ASYX responds differently to those values. IE #65 “PianoStage” #64 “PianoStageBrt” patches in my library are drenched in plate reverb. Also have noticed delay effects on some patches (IE #82 “Slap Synth 1” #96 “Slap Synth 2”) aren’t the same despite same values between the hardware and plugin.
Scaling between effect settings and effect engine seems to be off.
Modulated delays such as chorus sound fine.
“Omni mode” clarified: ASYX receives on any MIDI channel regardless of MIDI Receive channel in settings.
