I wanna use this so bad, but I am finishing up a couple of ep’s and don’t want to change my workflow right now. I can’t wait to go back to the s2400 though as soon as it’s out of beta
Thanks a lot for all the work and additions (especially the awaited ping pong loop )
I tested it and didn’t encountered the freeze I was about to raise for the august firmware. So far it seems stable.
Just noticed something though: when loop/slice is selected I heard the ping pong loop but when loop/slice mode unchecked it seems to go back to forward mode.
Noticed also that in the loop/slice params in event parameters there is no parameter that set the loop mode, perhaps it can be related to isn’t it ?
Are you sure you weren’t setting the loops in Multi-mode? Each slice can have it’s own loop settings, and so does the main pad. If you exit multi-mode, it might seem like the loop mode has changes, but it’s just reverting to the Pad loop, as it should.
Also, the loop mode isn’t saved as part of an event currently. Recorded notes will simply use whatever mode is currently active. We should probably fix that for the final release.
default template doesn’t seem to work ? if i power off and on again it reverts to ‘old’ default (i set up a filter with all ‘classic’audio engine and it’s not sticking - always reverts to HiFi)
here’s a really bad video
!!! FYI I have ‘load at start’ in preferences set to “nothing” as i don’t want my last project to load (rather I want the default to load).. is that right though ? that may be the source of the issue ?
Soooo cool!!!
Have been hoping for more filtertypes, especially HP with variable slopes. Yehaa!
Haven’t tried the beta yet, as I am finishing up af project, but really looking forward to it!
Thanx Isla
yes exactly I’m setting the loop in multi-mode on each slice and when it happens (because I haven’t reproduced it every time): as long as the multi-mode is selected I heard the ping pong loop then once deselected the slice’s loops go back in forward mode.
it has happened mainly when loading the project (it was a freshly created project).
Today when re-opening the same project I also noticed this time event’s level are not respected e.g: I got some kick rolls with different level and they sound all at full volume. I have verified yet there are no override set
Thank you for fixing the input gain on the Live Loops when switching to the sampler and back? Also the significant bleed from the dsp channels to the main outs when they’re not assigned to main?
Yes this is expected behaviour. When in multi-mode, you will hear the loop settings for each multi-mode slice. When not in multi-mode, you will head the Pad’s own loop settings.
@AMBOSS I think you found something. Right now, Tracks will only save their settings if there is a sample assigned. We’ll see if we can fix it for the final release. Thanks for reporting!
Ok I can understand that behavior when typing pads without recording.
But to my mind, it shouldn’t be the case for already recorded events. I mean if we record some events in the sequence with a ping pong loop, theses events should carry the loop settings in their-self. Otherwise it would mean they rely on a settings which can change at any time without being in override mode.
