Mickey
16
2021-08-12 Update
Fixes
- Fixed missed pad presses, and sensitivity setting
- Improved dynamic pad response, but still working on improving it further
- Constrained pattern length in pattern copy forum link
- Constrained pattern length when copying song to pattern forum link
- Fixed swing bugs forum link
- Fixed pressing pad in Swing settings changing selection if same pad pressed forum link
- Fixed Stop&Save in song mode forum link
- Fixed Run/Stop LED on when sampling with metronome forum link
- Fixed slices wrong after resampling & assigning, forum link1 link2
- Fixed text editor case bug forum link
- Fixed bug saving slices allowing changing to a midi bank forum link
- Fixed continue forum link
- Fixed organize not moving/copying override, mute, solo forum link
- Fixed TR Mode bugs forum link
- Fixed Mute/Solo in Nudge and Step Edit numeric view forum link
- Fixed Step Edit bugs with multiple nudgings
- Fixed Step Edit bugs changing pitch with encoder
- Fixed capital letters converting to underscores with sysEx track name change
- Fixed Stop&Save from Track Settings (or any screen other than Pattern or Song)
- Fixed MIDI tracks not sending note off in step program
- Fixed load kit (and project) not returning to same folder
Changes & New Features
- Added option to send metronome to USB forum link
- Added USB Mix Out First/Last setting to global settings - defaults to mix last!
- Added Mute Analog Outs setting to USB Audio InputMon settings
Note: analog outs are only muted if option is checked and USB monitoring is on
- Input monitor double-click now turns off both analog and USB, and turns on whatever was turned off in the last double-click forum link
- Added max sample time setting forum link
- Standardized undo behavior in Edit Step Parameters (save now automatic)
- Added next/prev step F-keys to Edit Step Parameters and nudge
- In Track Settings, changing bank now changes track being edited
- In Organize Tracks, the bank now follows the cursor, and vice versa forum link
- Added space to F9 in text editor forum link
- Added file exists warning saving new samples or slices
- Added pattern length display to Copy screen
- Changed 256t to Fine
- Added MIDI Control of Mute and Solo
- Added MIDI Control of Live Loops
- MIDI Implementation Chart updated
- User Manual updated
