S2400 OLED Issue – Still No Response from Support
Hey everyone,
I recently turned on my S2400 after a while, and after just a few minutes, the OLED display gradually became extremely dim. Now it’s barely readable.
https://www.dropbox.com/scl/fi/5irycycw548kcun756fap/display-dimming.mov?rlkey=wxfrnc9bwu4zi99v2anild348&dl=0
The display is actually much darker than it appears in the photos or video, to the point where it’s almost impossible to read.
I’ve tried different firmware versions, a factory reset, and adjusting the brightness, but nothing has helped. I also encountered an “Audio Board SYNC LOST” error.
I submitted a support ticket on October 28 with a video and photo, but it’s now November 2 and I still haven’t received any response.
Honestly, it’s pretty frustrating. I just want to get back to making music with my S2400.
Has anyone experienced a similar OLED issue? And is it normal for ISLA support to take this long to respond?
Thanks!
HARRY
This happened to me too and I had to order a new screen, and since my s2400 was under warranty they covered it.
As for ‘sync lost’, I was continuously having this issue too, randomly while working or using the DSP card. Not sure if you’re receiving clock from your computer via USB like I was, which was causing this issue for me, but after I switched to using an Innerclock SYNC-GEN 3LX for clocking, I haven’t had (knocking on wood) the sync lost crash since.
That should be fixed in the latest release firmware
Hi Brad, the “SYNC LOST” error is no longer happening. My display is still extremely dim, and I just want it to be clearly readable again, like it was before. Are you saying this display issue can be fixed with the latest firmware?
no, as I said in the ticket, because you are in seoul, it’s easier just to replace the full UI board.
