Is anyone here using the analogue filters and for which purposes, and what are your preferred settings for 1 and 2?
I’ve never had any luck with the dynamic filters on 1 & 2, so I turned them off. 3–6 are still on, though. Bass always goes through 3, drums always go through 4, and 5 & 6 are normally reserved for things I pitch down that need some of the aliasing smoothed out a bit.
I use a preamp plugin to make up the volume on 3, 5, and 6 . Drums get their own separate chain.
All the way digital, way more versatile. The high pass is indispensable on sampled hi-hats and having a ability for tuning in the low pass to remove just enough aliasing without muting it is a far better approach. Since we are not, or at least I am not, using filter sweeps and only using the filters at set amounts the digital filters get the job done far better.
right, thank you for your input
I don’t use them. The digital filter is solid and frankly having to juggle outputs is a pain in the butt (and I outboard process everything anyways).
Also imho 90% of the time, it being “analog” doesn’t matter and most people would fail an A/B.
My individual outputs are noisy when activating them, so I leave them off.
