ASYX V1.27 Update Released
You will find the new downloads available in your account.
Changes
ASYX v1.27
MIDI and Mix mode
  • Fixed MIDI routing so DAWs can address all 16 Mix parts.
  • New Mixes now start with all 16 parts enabled, assigned to MIDI channels 1–16.
  • MIDI Learn assignments are remembered across launches and shared between standalone and plug-in instances. You can switch controllers without having to learn them again.
  • Added MIDI Learn support for the ribbon controller.
  • Factory arpeggio patches now play in standalone without an external clock when using the default clock setting. Explicit external-clock mode still waits for MIDI clock.
Interface
  • The editor remembers its window size and whether the ribbon is open.
  • Restored the full-width ribbon, which opens underneath the main GUI, with smoother opening and closing transitions.
  • Startup credits no longer repeat when reopening an existing plug-in instance.
  • Improved Windows interface startup when using different display-scaling settings.
  • Added clearer startup error messages to help diagnose problems.
DAW compatibility
  • Fixed plug-in loading and editor startup in Cakewalk Sonar.
  • Fixed Audio Unit validation failures in MOTU hosts.
  • Improved reliability when loading projects and restoring saved plug-in settings.
  • Expanded AU and VST3 compatibility checks.
Installation
  • The Mac installer no longer requires you to close your DAW. Reload ASYX or restart your host when you’re ready to use the update.
  • Windows setup now offers Retry if a file is in use, rather than requiring you to restart the installer.
  • Made cleanup of older installations more forgiving.
Known limitation: Windows resizing has been improved, but some hosts can still leave empty space around the interface when the window’s proportions change.
The GUI now runs perfectly on Windows 11, and the window settings are preserved. Thank you!
Really enjoying Asyx. It sounds so good and really fun to program. Just curious if we will receive some sort of notification in the app when updates are released? Or will we just have to check the site/forums?
On my side I receive an email from Brad when an update is available.
A little notification inside ASYX plugin would be pretty nice to have as well.
Also, starting a new thread for the latest update would be very helpful.
