Need help on that :
- I have a loop playing on track 1
- I insert a plug in return A
- I go in the DSP Mixer and open the pot to send the track to A
I should ear the loop passing thru the effect on A right ? It does nothing.
Need help on that :
Same here. (using most recent firmware)
Me 3. Main bus fx work but not a & b send/returns.
And for me.
what plugin is on your return bus??
do you have it set to 100% wet in the plugin, if applicable?
how have you setup the send? pre insert, post fader etc?
turn return level all the way up and down again.
more info pls.
What plugin is on your return bus ?
Same result with all
Yes, i tried all range
Post fader by default, but i tried everything
Don’t do anything
Same here.
@ isla team, Is a clean install recommended or is it impacting everyone with latest firmware? If so, can you please let us know best way to clean install?
sorry about that one, fixed in dev
yeah that one caught me today, using dub delay, thought i was going nuts haha, glad its caught ![]()
I do have the same problem. Did this got fixed anytoime after this thread ?
yes, see the 2025-04-10 Update: Fixed non-working A/B sends
