Hello,
First thanks a lot for the hotfix firmware.
I think I’ve caught a new small ui bug when testing
In case you got some events recorded in the sequencer.
Normally you press Erase then the pads which got an event from are lighting and you press erase+pad to delete only the event concerned by the pad.
I noticed in Loop/Slice Multi Mode when you press Erase + pad (where pad is another pad than the currently edited pad) it doesn’t work correctly as it doesn’t erase the expected event.
