How to use the DSP virtual instruments?
Hi all! I’ve been playing with the new DSP, but I can’t seem to get any sounds out of the virtual instruments. I have an MPK mini keyboard hooked up to the USB Host port, but I am not sure how to play the instruments. Is there a place with a comprehensive overview showing how to connect a controller and play the virtual instruments? Youtube information is scattered and I can’t seem to find the right settings.
thank you!
Put the instrument in a dsp channel as a plugin ie channel 3. Then go to bank E and hit shift+pad3 (or pad with the same number of dsp channel you put the plugin on)
In midi setting activate send to dsp
Use the mpk to play
He’s right, you have to use a midi channel setup to then feed the DSP where the virtual instruments are. This is why setting up a template is useful I was confused at first.
thank you both! So far no success, but I think i’ll reset the whole S2400 to factory settings and I will try again
Hi there, I am having a similar issue after having followed the steps in this thread. Just curious as to whether you resolved this and if so how?
