It seems that Input Monitor settings are either not saved to the settings file the moment they get changed or are not loaded properly after turning on the machine.
For example, mine are stuck at: Analog Input: OFF, USB Audio: ON.
I believe this bug was introduced in the Nov 22 firmware.
Thanks for the bug report. It was doing that in previous versions too. Fixed in dev.
This is still happening in the 2021-12-24 Update.
@Petur Analog input monitoring always defaults to off on power-up. That is by design.
The USB monitoring setting was not being saved, but that was fixed in the 12-24 update.
Ok so it’s not possible ever to save settings where the analog input monitoring is on? That and to pan inputs is something I do every time I’m powering up for a new project, would be nice to be able to save it to global settings and save a little time. Or is there some reason for not allowing this that I’ve misssed?
Same here… I would also like to be able to save the Input Monitoring setting to default to On
Please create a new post in the feature requests forum instead of bringing up dead posts in future, please.
