Just a note that having used the beta, it seems some corruption was leaking into the system from the old config files. With the new firmware none of the chord pads seemed to be working in f1 mode, and it defaulted to reversing the controller direction which confused me until I found the setting. Doing a clean boot resolves these issues for me.
Thanks for the new bits of functionality - including being able to choose the f1 MIDI channel. Great work guys!
Additional: there is something a little odd going on. I clean formatted an SD card and then tried copying on the banks and sequences I had from the old cards - I would have thought this would be safe but again it messed up the Mempads. Chords were stored on them but going into edit mode showed that there was nothing there. It also lost the colour preference so somehow it’s affecting the config and other parts of the system. I will stick to working only from the Kordbot itself and see what happens. If it doesn’t behave I’ll see if I can track down what causes the problems.
