Level and Multimode button failure
I submitted a help ticket but so far no response so I will ask here.
After installing dsp card successfully
it seems my Level mode button has stopped working entirely and while Multi Mode button works with the remaining modes it no longer lights up.
The level button doesn’t light up either.
All other function seem fine.
I disassembled again to trouble shoot, make sure everything was seated properly. I noticed the long ribbon cable that joins the top section of the machine with the bottom was upside down ( the red was to the back but the writing was facing down.) I corrected this, reassembled and still no dice. I noticed there was a slight crimp in the cable as well, which I tried to gently straighten.
I triple checked all pin alignment.
Would it make sense that damage to the ribbon cable would cause failure with the mode buttons? Could the upside down installation at first have also caused an issue?
If anyone has had any experience with this I would appreciate any feedback
I asked in my support ticket if they would sell me a new ribbon cable so I could try this first before trying to initiate a send in repair.
Thanks in advance for any help.
Haven’t seen your ticket. but.
This is almost certainly damage caused when you took the machine apart.
People can be heavy handed when separating the top and bottom halves of teh machine and if you catch the metal on the bottom of the circuitboard you risk knocking off some of the tiny components.
I suggest that you carefully disassemble the machine, and look on the bottom of the PCB exactly around the area of the Level mode button. there are some small black diodes, they look like grains of rice and have 3 tiny metal legs. If you are luck you have knocked it and not ruined the trace, if not, you’ll need to get more surgical..
Thanks for the response Brad, I have sent a few tickets, I am guessing they arent getting through.
Is sending it back for a repair an option? It is out of warranty and I dont mind paying since this is obviously my own hamfisted doing.
Also it looks like the black rectangular bit you describe is knocked off- D7? There is one below pitch and envelope but not level
