Noisy main out
The Output on my 2400 which if I turn up the volume a bit on my Apollo 8 is noisy, this is without it playing anything . It’s like a bit of a crackly hum and is annoying. If I pull out the jacks/cables from the main output the noise stops so I believe it is the s400 that is causing it. Does anyone know why or have the same issue?
Does it go away if you…
Turn off the analog filters in the effects page
Unplug usb cables from the machine
Hi Brad, no filters ticked in the effects page and I unplugged the usb cable while it was on and nothing changed. It seems worse if the volume on the sound card is turned up . Not really that noticeable at lower volumes.
