Hi there,
Is there any likelihood of open sourcing the Kit Creator WebApp, so that one could, for example, create a little app to convert kits between file formats (there aren’t many s2400 kits around for download).
Hi there,
Not specifically a converter, but I’ve just made this break chopper tool that allows you to export .KIT files to Bank A.
Does this help?
I could look at adding a kit conversion feature - what sort of kits / formats do you want to covert?
Not sure if this helps but I’ve been using a terminal command to batch convert folders of stuff to 48k for the S2400.
Make sure you have ffmpeg installed and try running this in the sample folder of interest:
mkdir -p converted
find . -maxdepth 1 -name “*.wav” -exec sh -c ‘ffmpeg -i “$1” -ar 48000 “converted/$(basename “$1”)”’ _ {} ;
Not sure how this would work in windows but it works great on Bash terminal
