Hello everybody I finally started working more with the s2400 and i love the sound, groove and feel but i have some trouble with the Effect sends. When i put Plug ins directly on the channel everything works fine but as soon as i try to use the sends it does not work. Yes, i read the dsp manual. I set up a plug in on the return a and b and make sure it is wet and the return volume is up but i dont hear any effect when i send the chanel into a or b in dsp mode. Also the live effects dont work for me. Thank you for any help.
Did you install the DSP card yourself?
plug your headphones in to the s2400… do you hear the live FX and sends now?
If you do, then whoever installed the card didn’t install the internal audio cables correctly, meaning they are swapped internally. HP > MAIN MIX or some other version of that.
Thank you i managed to mix up all of those. Fixed !
