Question about MIDI Learn
So it is easy enough to activate and see the knobs turn that light blue, and when you select one it turns yellow; and I can see the banner below. But, there doesn’t seem to be a way to determine if a knob has been assigned, and which MIDI CC# has been assigned to it? It just seems to go back to the basic MIDI Learn display.
With the ENVs, if I assign a set of controllers to the AMP ENV, it seems those same values are also allocated to FILTER and PITCH? This might actually be a good idea, as it would simplify controller assignments by requiring selecting the particular ENV in the ASYX GUI? Otherwise I would have 3 separate sets of 8 controls…
