Resampling (from the track screen) produces silence instead of resampled sound
I have submitted this before, but it was closed when I said that restarting the machine fixed it.
But this has since happened to me a couple of times in varying circumstances, so I have no reliable way of reproducing the problem:
Sometimes, when resampling; no matter the track settings, and with sample gain turned all the way up, instead of a resampled sound I get a completely silent sample (nothing in waveform editor either).
When hitting resample, I hear the sample play, but when I confirm the process, it loads up an empty file. Same filename as original sample with resample attached to it, but no sound in it.
Sure, rebooting the box fixes it, but this is nevertheless a bug and should be eliminated.
Yeah this has been happening to me as well, and no file is saved in my project when this happens.
I’ve been running into a bug all night where resampling just results in complete silence. Honestly, it had me worried that my unit was hardware-failing. Given how much I’ve been relying on the S2400 for my sampling work lately, this has been the most frustrating setback I’ve encountered so far (I can live with the other minor glitches, but not this).
It really killed the vibe tonight. Even after countless restarts, the bug persists. I think I’m going to step away and mess around with Koala Sampler for a while until this gets patched. I’ll be back once it’s fixed.
The only thing that should affect the volume of resampling is the Record volume knob on the rear of the unit. I presume the problem is not that?
Seeing @bradholland get Isla being back up and running again and releasing bug fixes again made me so happy that I decided to get another S2400. Used eBay but great condition, great price.
While waiting for the unit to drive I wanted to ask: Have any of you encountered this bug? I reported it with a DAP card installed so that may have been the culprit then. Or have the latest updates treated this perhaps? I read through the bug fixes but couldn’t find anything.
Resampling happens before any DSP instruments and effects. So if you’re resampling something that’s purely lv2 instruments it would result in silence. Otherwise check the trim knob on the back, this has gotten me more than once too…
Well it definitely has not been the trim knob and it was a simple low quality resample. Didn’t work last year, hope this year will be better
