Hello all,
I’m totally blind, and I’m passionate about the S2400. I’d like to start a conversation about whether it could have a screen reader.
A lot about this machine already works for me: the tactile faders and knobs, the button combos, the keypad and USB keyboard support. I like that it was designed to be usable with your eyes closed, and much of it is. But think about what happens when you forget something. You open your eyes and look. When you adjust settings deep in a menu, you look. I don’t have that option. Yes, I can read the manual. I’ve already started a cheat sheet, and I’m memorizing button combinations and keyboard shortcuts.
For menus and settings, a screen reader would be like training wheels: something I could switch on while I learn the machine and switch off once muscle memory takes over.
But there are two everyday jobs where no amount of practice will help, and for those a screen reader isn’t training wheels. It’s the only way I can do them on my own.
The first is file management. Muscle memory can teach me where a menu item is, but it can’t tell me what’s in storage. The S2400 has two places to look: the internal flash memory, which has many folders of its own, and the SD card, with whatever folders and subfolders I’ve added. Every time I browse samples, load or save a project, assign a sound to a track, or rename a file, the folders and file names are different. Without hearing them, I can’t tell whether I’m in the internal flash or on the SD card, which folder I’m in, which file is highlighted, or whether I’m about to load the right kick or overwrite the wrong project. With that many folders, it’s easy to get lost completely.
The second is setting exact values. The faders and knobs tell me which direction I moved something, but not where it landed. Tuning a sample to an exact semitone, setting the tempo to 92 BPM, dialing in a specific swing amount, picking a MIDI channel, or setting a slice point or envelope time to a precise number all depend on reading the value on the screen. Without it, I’m guessing, and I can’t confirm whether I got it right or undo a mistake I can’t hear.
There’s precedent for this. Ableton supports an external screen reader for the Move, and the community Shwung project adds one that speaks on the device itself. The Roland SP-404MKII has several community-built options too, including one that’s purely a screen reader and works on the unit with almost no impact on Roland’s own features.
I know Isla is a small company, and I’m not asking anyone to drop everything. I’m also not willing to give up this machine, because of what it lets me do.
Whichever way it’s done, a screen reader has two halves: knowing what’s on the screen, and speaking it. Only Isla can provide the first half: a way for the S2400 to share its screen text, meaning the current menu, the highlighted item or file name, and the value being edited. The speaking half is where the community, including me, could help. I’m not a programmer, but I work with AI coding tools, and I see other members here are already using AI to build plugins for the DSP card.
I see two possible routes:
Without the DSP card: The S2400 sends its screen text out over USB, for example as MIDI SysEx. A small app on a phone or computer reads it aloud, using the screen readers blind people already use every day. That would work for every S2400 owner, and no speech would have to run on the S2400 itself. If the base unit has enough spare processing power, speech on the unit itself might also be possible, but only Isla would know that.
With the DSP card: The card is a quad-core ARM Linux computer that already runs third-party LV2 and VST3 plugins. Open-source speech engines like eSpeak NG and Flite are small enough to run on that kind of hardware. A community-built speech plugin could speak the screen text on the unit itself, with nothing else needed.
With AI help, I could design and build either the companion app or the speech plugin, test it, and share it free with other blind users.
A few questions:
For Isla: Could the S2400 send its screen text over USB, as MIDI SysEx or another way? And besides parameter mapping, does the S2400 pass any other information to the DSP card that screen text could be added to?
Base unit: Is there a thread on the S2400’s internals without the DSP card? I’d like to understand whether the base unit could speak on its own.
Headphones: The metronome and input monitor can already be sent to the headphones only. Could speech use the same path, either on the base unit or from a DSP bus or return? Then it would never reach the main outs or a recording.
For plugin builders: Has anyone built their own LV2 plugin for the card, with or without AI? What worked for building it for the card’s ARM processor? Is there developer documentation anywhere?
If other blind or low-vision users would find this useful, please add your voice here. I’m happy to design the feature, test it, and help build it.
Thank you,
Jose
