Having been told this is not an issue, I’d like to ask if anyone uses a USB(powered)-MIDI keyboard, plugged into USB-Host, (I use an Alesis Qmini in this instance) to record notes into tracks E and up, that then feed out to MIDI synths. I discovered this ability in the April 28th previous release, but applying this release, it might work for a moment after being powered off for a while, but pretty repeatably no longer works after a power off/on with this Qmini plain controller. (It’s tiny)
EDIT: After much testing, rebooting, plugging/un-plugging a Behringer Wave’s usb port to the USB Host on the S2400, usb-midi works as expected. The Alesis Qmini works flawlessly on a (RPi-3 powered) TastyChips GR1, but fails usually on the S2400, and once just halted, hung notes.
I am going to go away, and put it down to a “quirk” - there’s no way Brad’s workload merits documenting every silly USB-Midi controller out there and their stupid init foibles, when attached to a “drum machine”. E-MU didn’t have a form to whine about my old SP12 foibles, I got on with it. ![]()
