Allow loop point earlier than sample start point
I’d like to request a change to the Loop/Slice behavior: allowing the loop point to be set earlier than the start point.
Current behavior: When looping is enabled, the sample plays once from the Start point to the End point, then repeats from the Loop point to the End point. Currently, the Loop point is clamped so it cannot be earlier than the Start point — the Loop knob/snap will not move the loop point before Start.
What I want to be able to do: Set the Start point after the Loop point, so the sample plays a “lead-in” region first, then loops a larger region that includes audio from before the Start point.
Example: Sample spans A (beginning) to D (end). I split it into four points: A, B, C, D. I want to set Start = B, Loop = A, End = D. So the first hit plays B→D (the lead-in), and once it hits D it loops back to A and repeats A→D, giving me a loop that runs from the very start of the sample.
Why I want it: This is essential for certain types of samples, for example loop is starting before the one and in order to catch the groove a loop is often far better than multiple chops. Let’s say I have a one bar loop but in the original source material that loop starts before the one.
Ideal solution: Either (a) allow the Loop point to be freely set before the Start point, with playback behaving as “play Start→End once, then loop Loop→End,” or (b) add a toggle (e.g., “pre-trim loop” or “reverse-order loop”) that enables this behavior while still drawing a clear, click-free loop in the waveform editor.
Possible benefit to others: This would make the S2400’s slice/loop engine more flexible for live performance and resampling, where you often want a chop to trigger a specific slice but want the loop to breathe over a larger or earlier portion of the source material.
