Not sure if its due to the last few updates or not, but I’ve just started noticing -
When using the MAIN OUTS for quiet samples such as high hats and stuff, i’m getting a pretty loud click at the end of my samples. Almost like you would if you were not zero-crossing your chops or using any envelope. Thing is, i’ve tried alot of different samples and messing with envelope settings is not stopping the click issue.
If I use any outputs instead of MAIN - then my issue is completely resolved.
Anyone have similar problems?
EDIT: I’m noticing it after any samples that have dead air at the end of them.
@tweakrunsthis Thanks for the video. I was hoping you could share a project from your SD card that shows the problem. I need to check the WAV files and the settings in the actual project so see what the problem might be. PM me if you don’t want to upload it here.
I’m getting same issue on all channels even if use zero crossing or envelopes- it actually seems to be just pressing any pad that has sample on it because when I say -press pad 8 but I have it muted on my mixer the noise comes out of all channels (I tried muting each channel separately on my console ) and noise comes out of each channel separately. This is very aggravating as using multiple samples the noise adds up- my machine is in perfect condition and barely used so I really think it’s a issue in the electronics or update idk
This is exactly what is happening on mine as well- but it’s on all channels and even if I mute (on my console) all channels and one by one un mute that noise comes out every channel- did you hear back on any issue updates ?
hi this problem has been present since i got my unit. as far as i know it’s from first batch pre-order. hope this can help. Thanks for the team for all the amazing work!
