DSP/UI Requests for Workflow
Hello! I know @bradholland mentioned that work was beginning on some S2400/DSP stuff so I wanted to make a couple of (hopefully small) feature requests as a longtime S2400 user.
  • MIDI TRACKS - could the MIDI ECHO toggle setting currently in the SYNC menu be moved to individual MIDI tracks? This would allow the S2400 to more effectively sequence both modules and keyboards without a Local Off setting - sometimes I find myself having to jump into that menu and toggle it quite a lot.
  • FILTERS - is there any way to use the DSP to add different track filters but to have them live in the main filter controls? I love the stock filters but being able to choose different characters with and without drive would be great on a per-track basis. I know you can map the knobs on the DSP Mixer page but it would be cool to have that more integrated into the main workflow.
Can’t wait to see the new DSP stuff! There is so much potential there.
These are not specific to the DSP firmware.
and, in actual fact, we’re about to drop a new beta firmware that bring no less than 17 different filter models for a standard S2400.
Ah, fair point - I didn’t know if the DSP would be needed to have the juice for new filter models but the MIDI thing is definitely just a general UI/functionality thing.
17 FILTER MODELS?! I am gonna lose my mind, that’s so awesome.
I can’t wait for the LIVE FX tweaks/optimizations that you have mentioned as well in another post. S2400 is the gift that keeps on giving. :heart:
Another question/ feature idea -
How possible would it be to add a curve control to the decay phase of the ENVELOPE page? Just a single parameter that would go from the current curve as the middle value to full exponential on one side and full logarithmic on the other side? It would really help when shaping drum sounds.
I use the DSP card a lot - here’s my two cents on features that I think would be worth implementing:
  1. More than 32 controls for a plugin
  2. Show presets from a presets.ttl, and update the controls according to each preset.
  3. Midi out from dsp card, which I don’t think does anything currently. Is it feasible to run midi only plugins directly on midi tracks? I’m thinking scales, chords, arps etc. Or even on the the normal S2400 tracks?
  4. Sampling the DSP card. It’s currently kind of possible with the live looper, but cumbersome.
  5. Plugins loading files from the SD card?
