I find myself playing in first and edit (parameter overwrite) the sounds later most of the time. But when then adding more sounds, during recording, the original sounds are being played. Worst case this causes volumes go way up and my ears bleeding, but apart from that playing in new stuff is getting harder than it should or could? be. An option to choose would be ideal, to not bother people who like the current setup ![]()
The key is to commit your Playback Overrides to the sequence.
If you have Playback Override enabled on a pad (A button is lit), simply hold down the A button and press the associated Pad. You’ll see “Pattern Modified” on the screen. Now when you go into record mode, your pattern will match.
So it’s already there
I will try next session thanks! Does this also mean new sounds on that pad can be played, and then be overwritten in general for that specific pad? That would enable building layers much easier than I thought.
Yes ![]()
