[Fixed in dev] CC Not Responding on ch 10
Hi there, I have set up my midi map so that:
A1 Mode Percussion, Note C1, Channel 10
A2 Mode Percussion, Note C#1, Channel 10
Everything Else Mode None …
I can see control changes in the midi monitor: Ctrl Chg 10 7
But when I look at the main mix screen the levels of EITHER A1 OR A2 are not changed. If I switch both to CH 11 (and send CC on that channel) then one of them shows the changes (which I would expect). And I can control them via NRPN on the control channel but when I switch back to ch 10, no joy.
I don;t know if this is a bug or if there is a setting that I am missing somewhere.
