Would be nice if you could include the sample thru feature into the next upcoming updates. Be able to play your pattern while hearing your turntable play at the same time. Not certain if this feature is already in the system.
Oh, yeah I forgot about this video ! Thanks man.
so much to remember i know
, i just want my machine
It doesn’t work when you are in sampling mode. The pattern doesn’t play while the sampling mode is on.
True. That is because the whole sample RAM is dedicated to sampling.
LiveLooping can record while the pattern plays because the loops are shorter.
From the manual:
Memory Usage
There is no limit on the length of a sound that can be played from the SD card. The only limits
are on sampling time, and waveform editing.
Sample Time
The S2400 has 64 MB of RAM. Sampling uses the whole RAM. So, there is a 64 MB limit on the
sample size. Sample time depends on the bit rate and number of channels (mono vs stereo).
Waveform Editing
Normally, the RAM is divided into 32 play buffers. Sounds smaller than 2 MB can be edited in
the play buffer. Sounds larger than 2 MB but less than 64 MB can be edited by using the whole
RAM as the edit buffer. A pattern or song cannot be playing while editing a sound larger than 2
MB. Sounds larger than 64 MB cannot be edited in the waveform view.
i didn’t realise that is what you meant, your OP made me think you wanted to hear inputs while playing
